cyclone3350
The next step, was to start cutting out the necessary parts. For this, I cut out from the plans and glue them to poster board. After cutting to shape, I then tack them to the various materials with dabs of a glue stick, or for the larger patterns, a light spray of 3m 77. This holds the patterns down while tracing the outlines with an Xacto knife. Once done, just pry the patterns off. If the become a little too glued on, use a hair dryer or heat gun to soften the glue. Trust me, it is quick and works out well. For depron, rubbing alcohol will remove any unwanted residual glue. Here you will see the end result of the parts I cut from depron and made use of 1/32 balsa for double siding the front of the fuse and for a lightweight and stiff tail feathers. The wing ribs are 1/16 balsa and the spar along with the ailerons are 1/8 balsa.
