Hay Nic, or anyone, I have a question. Does the centre of the motor look to low, like not in the centre?? The power pod is a Nic one and not a FT one. I screwed the motor to the middle of the firewall. Maybe I should of raised it a bit. It will only do another 5-8mm up. Can't see any photos where it sits. Also if you remember it's 100% size, that was only by mistake. What do you think??
I also had a bit of trouble getting the CG right. I'm only using 2200 40c zippy, and I had to put 60g of lead in the nose??
