Hi All
I have Flip32+ FC (flight controller) connected to 4 OPTO ESC (DYS SN20A).
I have one "3A UBEC Module Low Ripple Bluesky".
Powering the FC was an easy task, I have just plugged the "UBEC 5v out" to one of the free motor pins.
Now I need to connect 2 more elements:
1.12 WS2182b LEDS (12 x 18mA = 216mA)
2. MICRO MinimOSD (500mA i.e 0.5 A)
1. Can I just split the UBEC 5V out into 3 pairs and power both FC, LED and OSD from a single 3A UBEC as there is enough current capacity ? what about noise ?
2. In case the answer for question No. 1 is NO, and I will need to use a second UBEC for better FC noise isolation do I need to share the grounds ?
3. the VBAT sensor ground comes directly from the battery can this cause ground differential ? do i really need to connect the VBAT ground or the "Plus" wire should be sufficient ?
Thanks TechSgin
Thanks TechSgin
