brettp2004
I just recently purchased the Taranis and I also got an Orange RX Module to go in it for BNF planes. I've watched several videos on youtube about a relatively simple antenna mod you can do to make the antenna come out of the top of the module instead of the back. However when I went to do this mod, I realized my module is completely different than the ones in the videos! I'm assuming is a newer one....
In the videos the SMA (I think) Connecter that the antenna screws into is on a wire that you can simply move by drilling a new hole. On my module, the SMA connecter is soldered directly to the PCB. There is no wire and no way of disconnecting the antenna without desoldering the old one. My question is, is there any way around desoldering the SMA connector? Can I use an SMA extension cable? Any ideas are appreciated.
