Given your info, I would guess it's the foam board then. Seems to be the only explanation. Mine's 31 oz with full fpv gear on board but using flite test actual kit (adams readyboard) the plane itself without electronics feels nearly weightless.the data from eCalc using the most apropriate ESC and most apropiate motor I could chose.
Acording to this it can fly with the existing motor........I think.....maybe somebody who can read this kind of data can translate it to me......
Right, it is a pita to get the CG where it should be without the spinner which is quite heavy and it is right on the nose of the plane.... Even with the spinner it is not easy to get it there....the battery has to be flush with the front-end of the fuselage....I found a thread talking about the material you used I believe.
https://forum.flitetest.com/index.p...utside-the-usa-us-citizens-pls-read-too.3558/
Looks like that stuff is over 300 gr a sheet if its 70cm x100cm. So you are correct in assuming that the material is heavier. That being the case I'd still get rid of all little extras that add weight. Just build a plane that is plain and simple then get a weight. Your gonna be heavier even then. I would also get a motor that produces more thrust. If you got enough thrust even a brick will fly ie: the space shuttle. I believe the guy who talks about using this material is in Spain and he said it messes with the CG.
If the rudder servo is in the back take out the rudder servo and fly with ailerons.
5mm thick, can't weigh a sheet, I was using 70x100 mm sheets and don't have one right now, I have only scrap right now....How thick is the foam board you are using?
most of the stuff we’re using is about 5mm thick. And weighs approx 193 Grams per sheet. Each sheet is approx 76x51cm. So, weigh a sheet of what you are using to see if there’s an appreciable difference.
As I said earlier that material according to another thread is over 300gr a sheet. Almost 3 times the weight of readi board. To save enough weight you'd need way thinner foam, and then you end up having to modify plans, and in the end you'd have a pretty spindly plane that wont take any abuse. By the way there is a thread on here of a guy who makes his own foam board with amazing results. Maybe that would be an option for you danizz?5mm thick, can't weigh a sheet, I was using 70x100 mm sheets and don't have one right now, I have only scrap right now....
Fly it man. Whats the worst that happens. It finds the dirt and you start fresh. Build a lighter one if possibleComing back to the eCalc data, can anybody tell me if it's worth trying to fly it as it is, or should I consider another motor. It is already built so that's it for now.....
I used the 3536 1200kv on 3s and it flew alright, not 4s fast but flew well. Are you using 4s on the 940kv?My 2 cents. Go with a bigger motor. On my FT Racer, i have a 3536 940kv with a 1045 apc prop. Close to 2.5 to 1 thrust to weight ratio.
It'll also give you more nose weight.
Peter
