Inq
I painted this DR1 using Apple Barrel acrylics from Wal-Mart using one of those wide flat foam bushes. But note that the streaking was done intentionally for this one.
Looks great. Just the color scheme I want to do.
A note on hand-launching. I fly with my transmitter on a neck strap and launch the plane with my left hand. That way I can use my right hand to set throttle (usually 1/2 -3/4 throttle depending on the plane) then move it back to the right stick so that when I launch I can immediately correct any pitch or roll deviations. I find this preferable to a right-hand launch where you have to get your hand back to the TX immediately after throwing.
Same on the neck strap and left hand launch.A note on hand-launching. I fly with my transmitter on a neck strap and launch the plane with my left hand. That way I can use my right hand to set throttle (usually 1/2 -3/4 throttle depending on the plane) then move it back to the right stick so that when I launch I can immediately correct any pitch or roll deviations. I find this preferable to a right-hand launch where you have to get your hand back to the TX immediately after throwing.
Awesome job! Looks great. Can't wait to see the restThis was my first FT plane and found it challenging to fly. I recommend maiden on a calm day. View attachment 234385 I didn't crash but for a beginner, I had my hands full. I tried safe but it actually flew better without safe. Have not flown it for a while because we get so much wind here. Still one of my favorites beause I have always loved the tri-plane. I will build this again with some modifications. My son turned the bi-plane into a 4 channel plane and it flew great and very fun! It's hard to keep the landing gear from getting damaged, though.
It's "vintage".I've seen 3 year old's finger paintings that look better than this. I sure hope multiple coats improve this.
It's "vintage".
Fortunately, the FT foamboard seems to take paint a lot better. I can live with one coat on it. The plastic that needs to be red has taken three coats and it still looks like finger painting.
What kind of paint are you using on it?
Someone suggested (maybe you) I use acrylics on it... cheaper, easier and no fumes. Seems to be good on the foamboard... pretty crappy on the plastic.
That's a beauty, I like the weathered look. Came out really well.Put a fork in it!
This one is done... ready for maiden. It will certainly be the only one painted, and considering my list... it may be the only one done.
That was a decent movie. The flying scenes are all CG (and quite unrealistic from a physics standpoint) cut in with closeups of the actors in movie-prop airplanes. I was particularly amused/annoyed at the scene where they're driving a little biplane around and crash it into a haystack. The plane they used is a 3/4 scale replica of the Curtiss Jenny, an American training aircraft that never made it to Europe, and you can see the modern VHF antenna sticking up from the turtledeck.I watched the Red Baron movie last night for context. Most of it had to be CGI... I can't believe they had that many planes available. I was even watching for details to see if they were using re-creations. One scene showing the flight line starting up and they certainly looked like the old Rhone rotary engines starting up. Cool stuff.
I love watching aviation movies. You can almost always find something. If you are into that type of thing go back and watch The Flying Tigers with John Wayne. They have a bunch of …let’s say…Hollywood P-40s sitting on the tarmac. There are several scenes when they are taxing around plywood mock-ups. Good fun.That was a decent movie. The flying scenes are all CG (and quite unrealistic from a physics standpoint) cut in with closeups of the actors in movie-prop airplanes. I was particularly amused/annoyed at the scene where they're driving a little biplane around and crash it into a haystack. The plane they used is a 3/4 scale replica of the Curtiss Jenny, an American training aircraft that never made it to Europe, and you can see the modern VHF antenna sticking up from the turtledeck.
...Now I want to watch it again...
I had an old player piano that was green and brown, looking the same way. They called it "distressed". Good luck on the flight!I've seen 3 year old's finger paintings that look better than this. I sure hope multiple coats improve this.
How did you mount/attach the cowl?Put a fork in it!
