Matthewdupreez
but doesn't it have a screw on little thing that clamps onto the shaft?
Yeah, it's different. It's almost impossible to break a prop with one.so its different from the motor accessory that the flitetest guys use? does it make the chances of breaking the prop less likely?
Can you order from this site? I have several of these and they are very good motors - perfect for C pack planes.does anyone have a link for some from aliexpress? I definitely need some of them those props are rather pricey, and do they work on the c power pack?
Yeah I use them on all of my flat out 3d planes and I haven't had a broken prop yet. Just make sure the rubber bands you use are not Damaged, I've crashed a few airplanes from props deciding to go into a low earth orbit!does it make the chances of breaking the prop less likely?
I get the struggle with the prop savers but, If you space the prop correctly and use the higher quality ones like the one that come with rimfire motors they work alright, especially if you know your going to be wrecking a lot. Personality I only use them on my 3d (and 4d) flatout airplanes because I wreck them trying new stuff every time I fly them.I personally hate prop savers. I find propellers never hold their balance when using them. Currently this is the only plane I have that uses one and I have propellers going on 4 years old that do not have a prop saver. Now that I've been flying a while I never have prop strikes.
Same - also having a well-designed motor makes a huge difference. On my gforce motor the o ring is so hard to get on and off and the threads on the screws eat into the band causing it’s to develop tears. My T-motor however has such a nice design and is super easy to use. I honestly love the design, but it is 4x the price lol.I get the struggle with the prop savers but, If you space the prop correctly and use the higher quality ones like the one that come with rimfire motors they work alright, especially if you know your going to be wrecking a lot. Personality I only use them on my 3d (and 4d) flatout airplanes because I wreck them trying new stuff every time I fly them.
I will try although shipping to South Africa may be priceyCan you order from this site? I have several of these and they are very good motors - perfect for C pack planes.
https://hobbycool.com/products/2832-brushless-motor-for-r
Hope you get some decent weather to test fly.
You restored it to fly it, not look pretty in some museum.
