RC Lover
Hi everyone,
after building 9 prototypes of the X-37ABC, without being able to design a fuselage that generates enough lift (due to low airspeed), I've decided to use the last prototype I made, as a base for the shape of a proper new RC airplane... with wings... this time! This is the Very Easy Plane (V.E.P.) and I've "flite-tested" it a couple of times, with very good results.
http://www.instructables.com/id/RC-VEP-Very-Easy-Plane-Built-Using-Polystyrene-Piz/
V.E.P. has been designed, built and flown, by me and assembled with £15 F939 parts...
http://www.banggood.com/WLtoys-F929...ller-022-p-947009.html?p=ZL2104540902201404G2
http://www.banggood.com/WLtoys-F929...are-Part-p-930768.html?p=ZL2104540902201404G2
http://www.banggood.com/WLtoys-F929...are-Part-p-930767.html?p=ZL2104540902201404G2
This nosecone will make the life of the propeller longer...
http://www.banggood.com/WLtoys-F929...or-Cover-p-930773.html?p=ZL2104540902201404G2
A female Losi connector to swap the JST 2.0mm PH JST of the standard PCB
http://www.banggood.com/DIY-1_25mm-...dcopter-p-1080391.html?p=ZL2104540902201404G2
I own already a "multi-functional" FlySky FS-T6 Transmitter
http://www.banggood.com/Flysky-FS-T...X1-Mode-2-p-73199.html?p=ZL2104540902201404G2
You need also some UHU Por (foam friendly)
3 polystyrene Pizza trays (the less difficult part of this project was to eat pizza)
2 bamboo skewer for barbecue
2 popsicle stick
a piece of velcro for the battery
2x 1mm pushing rods
2x horns (I used servo arms shaped for this purpose)
2 popsicle stick
2x 1mm pushing rods
