Form its behavior, It looks as though you need some right-thrust on your motor. It may be piloting, but it looks like in a straight line it wants to pull left. A little thrust angle and you should be pretty good. This airplane is in the "moderate" sense of having a short tail so you may need to enlarge the V-stab as well, especially if my assumption of your thrust angle is wrong. When you scale these aircraft down you sometimes have to make compromises in scale proportion since the air density does not scale with them.
Great job though! looks like a hearty model with a lot of potential once the kinks are worked out.
