I have a lot of propellers and I can only use CCW propellers though. I was wondering if you reversed the Power pod angle could I be able to use the CW Propellers as long as I reversed the motor too.
I use any suitable sized prop regardless of whether it is CCW or CW. You just need to get the thrust angle correct.
Reversing the power pod angle or even, (in the case of mighty minis), mounting the powerpod upside down allows the use of CW props without any really noticeable detrimental effects.
