I had a crash earlier this year and had not tested things since it was cold (I only have one set motor + esc), I am not sure if this is a motor or esc problem.
Everything was working well but testing today in a new plane, I connect everything as usual, the rx gets power and servos work fine but motor won't turn.
I tried to see how much voltage I am getting out of the esc wires (if that matters):
ESC cable Red, Yellow and Black going to motor:
Legend:
R+ => Red wire to volt meter positive
Y- => Yellow wire to volt meter negative
Results:
R+ B- = -1.1v no throttle, -1.3v full throttle
R- B+ = 1.2v no throttle, 1.4v full throttle
B+ Y- = 1.4v no throttle, 1.4v full throttle
B+ Y- = -1.4v no throttle, -1.4v full throttle
R+ Y- or R- Y+ = 0.0v
Not sure if that tells anything, thinking something on the esc might have melted (see pictures) and so it's not giving full power available or motor took too hard a hit during crash (I checked continuity between motor wires). I don't have another esc to test with sadly. I checked all settings on my TX, tried inverting channels, switching wires, checked throttle curve, even tried using an unused plane model in TX (default).
Any idea? Is this my new glider only ESC?
Legend:
Results:
