So I've been having this issue with my newly bought emax nighthawk pro 280. For whatever reason, when in mid flight the quad will jolt in terms of roll or pitch, and sometimes throttle, almost as if I've applied a very small but sudden action on the transmitter itself. But I could be simply hovering steady in the air and the quad will suddenly shoot upwards in throttle for no reason.
It's mostly obvious when I'm flying fpv, as I can see the jolts much clearer. I was wondering if this could be an issue with the receiver on the quad picking up false stick movements or something. It has been in a few crashes and there is a noticeable crack on the receiver, but it hasn't dented or anything so I'm not certain that this is the cause.
It might also be worth mentioning that I have altered the values in cleanflight. I adjusted the roll, pitch and yaw trims on my controller so that the transmitter middle readings in cleanflight were as close to 1500 as possible, I also altered the minimum throttle value and enabled motor_stop, because the motors were spinning too fast with my throttle at it's lowest point, and the quad would only just descend.
I've also altered altered the rates, and expo, I'd be happy to quote the exact values if necessary.
I hope I've given enough information. First post, rcgroups newbie here. Thanks in advance
update:
https://www.youtube.com/watch?v=b4YiPxYZUaY
update:
