tommy_mental
Hello,
I have some problems with my FPV system's range and I'm hoping you guys can help me troubleshoot them.
To get into FPV I got me a cheap Boscam-like 5.8 gHz 34$ USD system (here) and a set of cloverleafs (here). I use a board camera with it on David Windestal's tricopter design. The Video transmitter (with the 3-blade antenna on it) is mounted about an inch off the back end of the trike frame (the Y piece). I use a 35 MHz Radio with the antenna on the very front of the Y-frame. Everything is powered by a single 2200 mah 3s battery. The video receiver is mounted on a ~1.8 meter tall wooden pole (and I don't stand in the way of the signal).
So far so good.
The problem is that if I get more than 50 or a 100 meters away from myself I start getting a really bad signal and almost lose the feed. I know that probably the Tx/Rx system is to blame being the cheapest I couldn't find, but maybe I have something setup wrong - I feel that 50-100 meters (or even 200) as compared to the advertised 2 km range is a huge difference.
Is there anything I can to do improve the range (except buying a proper set of Video Tx/Rx)?
Thanks for any help!
So far so good.
