cdfigueredo
I have been interested in FPV flying for a while now and I just have the possibility to acquire the equipment. I have been doing a lot of reading to avoid throwing money away and I think I have a good initial purchase. I would like to get your opinions.
After some research, my target goggles are the EV800D with very good reviews and and most importantly, within my budget
And i am thinking to go with Wolfwhoop WT03 as Camera+VTx. This cameraVTX is pretty the same as the Eachine T03.
This configuration should work according to almost all reviews. It should work perfectly to at least start doing some initial flights and get used to FPV flight. But...
My concern is that this configuration only emits up to 200mW which could be a problem with a fairly discrete range (I'm not talking long range, just 500 meters or less). In several reviews you can see how video noise starts to appear after 100 meters.
The main advantage of this configuration is basically the price and that it comes with a leaf antenna.
The other fairly common option is to use VTx and camera separately like the AKK KC02
The main advantage of this variant is that it reaches up to 600mW which is quite a lot of power and you can also replace the camera in the future with a better quality one and still use the same VTx. But on the other hand, the cost is higher and the antenna is not the best, which implies having to buy a new antenna.
So, what do you advise me?
