Hi everyone. Ages ago I bought a orangeRX openlrs 1W module second hand. I had no idea what I was doing back then, so It got thrown into my box of parts for ages. Since then I've got good at fpv and wanting to give long range a shot. Pulled it out and tested it and it worked fine. I had no idea what firmware the previous owner was using on it, so decided it was a god idea to re-program it. After watching some tutorials thought it was going to be a piece of cake. I'm pretty familiar with arduino. So I download the code and files from this page.
https://github.com/openLRSng/openLRSng
The only changes I made to he code was un-comment "#define COMPILE_TX 1", and "#define BOARD_TYPE 2" to set it up with the orange module. I set the jumper on my FTDI to 3.3V, plugged it in the right way, and hit upload. everything went on it fine, and there was no problems with uploading. However now when I plug it into my radio and power it up it flashes the red warning light once and then does nothing. Tried holding the bind when powering it on and the same thing occurs.Tried re-flashing it and it lets me reprogram it, however does not fix the problem.
So I thought that the jumper on my ftdi could have played up and given it the wrong voltage. I verified the vcc pin and it was 3.4V with my multimeter.
My radio is also set to 8ch ppm. I have verified that there is a ppm signal reaching the module. There is also a frsky dht module tied to the ppm, but I dont think this should make a difference.
Not sure what the problem is. I don't think I've made any mistakes. Perhaps someone has a cue as what is going on, i certainty don't.
Thanks, David.
Thanks, David.
