Fluburtur
Cardboard Boy
I will most likely be participating at the Maker Faire Paris in november to show off my rc planes but since you cant really fly a plane in there I thought about building a tank that peoples can drive.
I looked at sever designs and decided on doing something close to the AMX-13
The oscillating turret system is interesting and it is a french tank so peoples will probably like that.
I will be building it mostly from thin plywood, cardboard and foam with 3d printed parts for the mechanical stuff.
The scale is 1/5 so that gives a 1m long hull, maybe a bit much for a first tank but I should manage. I will be powered by a pair of large 400kv motors geared down a lot to give smooth low speed driving, I alreadu ordered the parts so I will try to start building the hull soon.
I did a bit of the 3d model already.
I modified it to have the drive at the back instead of the front, this way it is more efficient when driving forward.
It wont be a 100% scale model, just close enough that peoples can figure out what it is but I will try to get it fairly close.
As usual I will post progress when it comes.
