I have used the one here in the past
http://adamone.rchomepage.com/cg_calc.htm
I don't actually use the CG it gives me, rather I use the old fashioned 25% of the MAC it calculates. On my 540-like scratch builds this has worked fine.
I read that you calculated an AOA for the wing prior to install - can you share how you did this? I normally install the wing (symmetrical) with 0 degrees incidence from the horizontal elevator and use elevator trim to get it flying level. But now I am wondering which gives you better performance, 0 degrees incidence with some up trim or some small upward incidence of the wing? Thoughts?
Thanks.
p.s. - Still practicing to make those wide bevels with blades, as you suggested, but I keep messing them up. Any tips or tricks on this. As an alternative solution I have started to use a hot iron for this and it works well but it really slow.
DamoRC
