So I got some more money. And then I bought the FT Bushwacker with Power Pack C, a hot glue gun, and some other miscellaneous supplies. I've maidened that one and it has a few issues (the pilot being one) but it's going well. I wanted to practice building and flying something a few times before I get this Sky Tiger up in the air. I imagine I'll buy and build another FT plane like the Spitfire or Mustang to practice flying low-wing. Might even do a Sig Four Star 20 EP as well since it's smaller than this but should have a similar flight characteristic. Anywho.
I got more money since then and bought some supplies and material for covering the balsa frame. I have watched a ton of YouTube videos and read a few articles on how to do this properly so I was well prepared. I practiced covering the original tail surface first. This tail surface isn't quite right and was reconstructed after I destroyed it getting it off of the fuselage. I knew I'd want to experiment with covering so I built it back up to allow it to be a test platform before I started working on the newly built tail surface and refurbished wing and fuselage.
I think it turned out rather well. I had some trouble on the inner curve of the vertical stabilizer where it goes to a point and blends with the body (no pictures) but I did learn a little. First, I think that a smaller iron (like the Monokote Trim Tool) would serve me well for this. Secondly, I was using too much heat when trying to set the adhesive so the film was shrinking at the same time. It wasn't a problem on the larger flat surfaces but it really hindered me on some of the curves. I turned down the heat and things went much smoother.
I also learned that using the iron to shrink the film (vs. a heat gun) cause the adhesive to stick to the ribs inside the tail surface. It isn't really a problem (and is probably stronger) but it doesn't look as nice. The blue side I used the iron to shrink and the white side I used the gun.
Overall, I'm happy with the results for a first attempt!
Next steps are to get the trim tool and then start covering the real parts using the lessons I learned. I'm looking for an airplane template that I can use to draw out my color patterns so I have something to work from than just a mental picture.
