Hello people!
I was at home reading whilst wondering what to do last night when I got an idea. I haven't been able to put the sliders on my MPX radio yet because they cost a fortune and are hard to get hold of. But then I remembered I still had the 2 pots from the Losi car radio that I used the guts for to make my homemade 2 channel radio for my little DLG. So off I started hacking away at the MPX to add a pot to each corner for channels E and F, and I can always add an internal switch to change from slider to knob when I get the sliders and use whatever is best for that particular model. I just love the way tray radios are designed to be adaptable and upgradable!
Anyway, I added the pots to their position, and put the Losi trim knobs on them as they happen to be the same colour, and I am very pleased with the final aesthetics of the upgrade! Now I can have 2 proportional channels for things like proportional flaps, proportional butterfly, proportional spoilers, gyro gain, etc.
I've already done some upgrading on this radio, as the 3010 comes as basic 4 channel radio that is upgradable to 9 channels plus 6 multifunctional switches (for things like dual rates, expo, channel inhibitor, etc.), plus digiknob for inflight adjustments and plus a memory switch to change between 3 models inflight, which is the radios version of flight modes. I've already added 3 of the multifunction switches and a 3 position switch for channel G... all the switches were taken from a broken Futaba T6EXA, the 3 position switch being originally the trainer switch which I opened up and renoved the spring mechanism off of with an exacto knife.
Now comes the connecting part of it all... and here is the issue. The pots were designed to be able to utilize the entire movement of the servo with only a fraction of the pot movement, as with the case of gimble pots for example. But now the pots will be using their entire range of movement because of the application. But I think because of this, the resistance may be too great. Now you can reduce the resistance value by adding a fixed resistor in parallel, but I'm not sure in this case if it would be a single resistor per pot between the two outer pads of the pot (positive and negative), or if it would be 2 resistors per pot, one from one outer pad to the middle one (positive and signal), and the other between the middle pad and the other outer pad (signal and negative).
Any ideas anyone?
Any ideas anyone?
