Wernher von Braun
Hi folks, I want to build a rocket powered ME 163 that will be propeller driven until ignition of the motor. I'm brand new to this hobby and have made an FT storch and painted to look vaguely like a real one.
The motor that will be used in the ME 163 is still in the planning phase but I am hoping for a motor that will fire for hopefully 10 seconds and give a scale amount of thrust. I expect the motor to weigh between 1-2kg. Can someone help me come up with specks for how big this plane should be and what to put in it. I want to make it out of foamboard and I will insulate the inside of the plane from the heat as best I can. I plan to have the motor in the COG of the plane and use thin steel tube from a can wrapped with a layer of ceramic Fibre As the exhaust pipe. I will also have air scoops to channel air to the inner wall of the exhaust tube and motor to keep it cool. The exhaust will also push on this air and suck more through the tube, recovering a little more thrust.
