Update #2b
A little dilemma...
So I have built the fuselage sides/engine fairings (not sure what to call them, TBH). It took me 5- 6 hours to design and build these, and they turned out quite all right. It was a bit challenging, but also quite fun in all.
I actually intended for them to be optional, as they add weight (16 grams each) but also take away a little bit of wing area. So not only will they harm the plane's performance a little, but it's likely that if I use them they will actually tip the flying weight over the intended 600 gram limit.
Still with several hours invested (and being a sucker for scale looks) I am really pretty sure that I will glue them on in the end
. So the solution I am contemplating is to finish the plane and weigh it before that (optional is optional, after all
) then put on them as the finale of the build.
And I am thinking I am going to redesign the fuselage for the second ('production") build, so that they become an integral part and not just add-ons.
One interesting thing i discovered is that the same glue/label remover I use to peel off the paper, when applied directly to the foam, softens it making it a bit mushy to the touch but also easier to curve and bend without creasing or cracking.
I expect the rest of the build to be quite straightforward from now on, the last remaining thing to figure out is how I want to lock the front and canopy hatches, other than that - the finish line is in sight.
