I would suggest something other than a bungee. Once you heat the wire it will give and you will get warped ridges in the foam cuts. With that bow I would suggest another wire and a very strong spring. It will remove the slack when the wire heats but not give by dragging the hot wire. I use piano wire... like from an actual piano. Picked it up from a repair shop. Got about 10 feet of it for $1. THeey have it by the spool and usually are good about helping hobbyists. I'll get my calipers out tomorrow and measure it for you. I'm taking off work all next week so if you are free let me know.
