JasonEricAnderson
FT-OV-10 Bronco BETA 0.2
Here is the next version of the BETA plans. (STRESS ON THE WORD BETA. When I feel like I have a final version I'll post an article)
What's changed in this version
I still haven't put in the shape for the wing slot because I'm not all that confident that my virtual fold over will match what happens with physical foam board. Once I build a new wing from these plans I'll trace the physical wing profile and transfer that back to the plans. I'm also thinking of having at least two versions of the canopy, the current, simplified geometry and another, more complex bit of foam board origami that looks smoother and more curved. It would be more scale and similar to the posts Gunhog put up.
I did get a new set of parts so I have matched motors, ESCs, and some larger batteries. However, I purchased the wrong battery connectors. I wasn't paying attention and got XT90's rather than XT60's. The 90s are HEEEUGE! they look like you can use them to jump start a car. I gave them to David W. at the FT Open House last week.
Next steps for me:
- Fixed the spar tab locations
- Deleted one spar (No need to two patterns)
- Corrected spar overlap length (I think)
- Fixed spar hole locations in wings and moved forward slightly to avoid nacelle tab holes and hopefully fall in a better part of the wing folds per Gunhog's input
- Trimmed down vertical stabilizer to remove unnecessary material
- Added KF style fold-over panel for front of horizontal stabilizer
- Notched in the elevator sides 1/8" to avoid dragging on the rudder
- Repositioned the nacelle tabs/notches on both the nacelle and wings. The power pod now uses one of the voids to anchor the front tabs of the power pod, thus simplifying the cuts/folds.
- Reorganized the parts to make better use of space in the plans
Next steps for me:
- Building a new wing/spar and getting that slot profile
