ScratchWarbirds BF 109 F-2 / G Build
Fallegon
ok well here it is. I have absolutely no video editing skills so be patient with me as I figure out a style. Also I know the plans may not be what you're used to but I think this way works out well. Please let me know if you have any constructive feed back about the plans or overall video I want this to be easy to understand.
-----------------Materials----------------
2 - Foam board sheets.
2 - Cardstock sheets.
4 - BBQ skewers
2 - Coffee stir straws.
Hot glue gun
Razors
Preferred music wire for push pull rods.
4 - 9g servors
------------- Plans ------------------
https://www.docdroid.net/LxWqGpO/bf-109-f-2g-plans.pdf
------------- STL Files -----------------
Motor mount: https://www.thingiverse.com/thing:3249274
F-2: https://www.thingiverse.com/thing:3245570
G: https://www.thingiverse.com/thing:3245591
kilroy07
For the STL files. Seems to be a pass through through youtube (it shows a link to continue to the thingiverse site.
On a couple of the pieces in the plan there were two lines, might be a tad confusing which is the cut line.
Pictures for the fuselage might be a tad better as some of the dimensions were hard to make out.
Fallegon
Ok I'll look back throught it when I get some free time. This is such a busy time of year to be starting this :p.. Also I my plane met the ground this morning at full throttle and this was the result. I have to say, I'm surprised it held up as well as it did. I was worried about the flimsy feel of it but heres a pic.. Nose cone and prop are destroyed natrually.
Fallegon
Alright so Iv updated the plans file but theres still some work to be done. Also plane is pretty much fixed.
O also where should I posts these build threads.. here or the plans one?
Chuppster
Man, if you invested some time into CAD you'd have some good plans for a slick bird! As it stands, I'd say this is tough to replicate.
Chuppster
So the formers are supposed to be print and trace. Is it the images that are confusing?
Well, it's just a lot easier to have everything drawn up in CAD so we can print it out and consistently build your design. As it stands it'd be a lot of work to follow plans based on measurements. Scaling is a challenge too. How do we know what we print is the correct scale?
