D Djs922 Junior Member Jan 28, 2015 #1 Jan 28, 2015 #1 How do you setup 2 servos on a spektrum receiver so they both work setup to one switch on the transmitter?
Raptortech Foam Addict Jan 28, 2015 #2 Jan 28, 2015 #2 You should be able to simply use a Y harness to connect both servos to the same pin on the receiver.
pgerts Old age member Mentor Jan 28, 2015 #3 Jan 28, 2015 #3 To get a correct answer you need to specify the model of the transmitter and receiver and the use of your servos. Are it two servos for aileron or flap or gear or bomb drop and you need the servos to go opposite directions with the switch?
