I could use some more experience with repairs.
Careful what you wish for...
It's not a matter of if, but when...Careful what you wish for...
Chicks dig scars... and pilotsWell, I can officially say that NOT flying is bad for you lol.
Was going to go out flying and then I thought, na, I'll weld those pegs onto that mini motor instead.
After cutting the tubes I'd left sharp edges intending on smoothing them once the job was done but before I got that far I walked past it and the sharp edge sliced my leg ha ha.
So off to the hospital it was to go get stitched up, at least the nurse was super cute
View attachment 140496 View attachment 140497
I'm covrred in scars from accidents lolChicks dig scars... and pilots
I am wondering how you get up to those heights and distances with just batteries that fit in these airframes. You say all it takes is a 4200 mahWinds are close to gale force here today so unfortunately I won't be getting to test it but I've built a 57.5" FT Storch wing for the cub for giggles and to see if I can extend my flight times.
Flying with an all up weight of 1.1kg on a stock cub wing demands 80% throttle just to maintain altitude and gliding involves a lot of up elevator and I decend 2x faster than on a 2700mah 3s from being so heavy.
so a lot of the potential from carrying a 4200mah 3s is lost.
The storch wing will give substantial gains in lift and should also allow me to land at a much lower speed than I'm forced too currently when I'm flying heavy
The cg point on this wing barely affects the original cg point on the cub, it's made it a fraction more nose heavy but I carry 30g of weight in the form of car wheel balancing weights and can easily remove one or both of them if it turns out to be too nose heavy in flight. View attachment 141064 View attachment 141065 View attachment 141066
That is nuts, 5000ft. You should put a digital thermometer to record the air temp up there to see what your battery is subjected to as far as cold temps. Maybe insulating your battery will give you longer flight times. I'm sure the larger wing helps with the lighter air density up there as wellI can hit the clouds on a 2700 if they are fairly low, say at 3000-4000ft and i climb fast enough but its exhausted by the time i get there and i have to immediately start gliding.
Im hitting 5000-6000ft on a regular basis on the 4000 and 4200 mah packs i use, they are a very snug fit and the absolute maximum that will fit inside the power pod.
I couldn't help myself , i had to go out and try the storch wing on the cub even though its 35mph winds gusting to 40 here at the moment lol.
i am pleased to report that the cub flew great!
lift is up by massive amounts and gliding requires much less up elevator, i did not need to change any nose weight and kept the balance as it was and it was fine
i hit at least 6500ft today despite having to spend large amounts of time in level flight trying to make back ground where id been blown a mile away by the wind.
i spent 25 mins in the air on a 4200mah 3s, some of that was spent on about 30% throttle on a very slow decent from altitude but i recon on a calm day it should be capable of 30+mins of level flight on a medium throttle.
Unfortuately , my hd cam did not record fr some reason so i have no footage but it will be in the air again very soon, we can all be sure of that ha ha!
What Tx are you using again?no need for insulation, im pulling a solid current from the pack and my 2700 packs come down burning hot (why my cub has vent holes in the nose) and the 4000 and 4200 packs come down warm during spring and summer and i actually get a longer flight time on the cooler days.
i have been getting 3mins more out of my packs these last couple of days where its cooler vs the 32c weather we have been having.
lipos have a Goldilocks zone, they like a band where its not too hot and not to cold to perform there best and useable capacity is reduced outside those temps, very cold temps will zap usable capacity but do no damage which is why in the winter i close up the nose vents but the summer the very high battery temps i sometimes land with are not at all good for the packs chemistry!
although im flying at a decent altitude its still not high enough for the temp to get really low compared to ground level, my tx supports temperature telemetry sent from a module connected to my rx and i have one (it came with my tx) which ive never used but i might have to hook it up and see what the difference is View attachment 141117
What was the price tag on this unit?Flysky FS-i10
It came with a bundle of 4 different sensors- RPM (optical), RPM (magnetic), Temp, voltage and something else which i still dont know what its for which looks like a hub but the sensors can all link and one then connects to the rx without that unit so i will have to look it up.
the only thing i need is voltage and i modify my rx's to monitor voltage on one of its pins without the need for an external sensor so till 5 mins ago id not even taken those sensors out the packets and ive only just connected them for the first time in 2 years lol View attachment 141119
Love my tx and couldn't live without the color touchscreen but if you are not already used to a touchscreen then the jumper T-16 is a feature packed radio with more options available in it than mine.What was the price tag on this unit?
I ask just because I have the low end of the Spektrum brand with the DXe and it is very limited as far as it's versatility, and communication. I am just getting frustrated with it as of late. It was good to get the basics down for flying and hooking up basic links to 4 channel and some flaps or landing gear. But now I am noticing there are ways I would like to set things up and it won't do it, or I just can't find it.
So i need a new set up to be more consistent and versatile. Just looking at options
I paid $100CA for mine and I have to hook it up to a laptop to program anything. The tether cord for programming was another $27CA, and if you don't already have a laptop there is that cost as well. So realistically I spent that much or more already to get the cheap stuff. Just makes sense doesn't it... wanna buy a DXe, smokin deal!Love my tx and couldn't live without the color touchscreen but if you are not already used to a touchscreen then the jumper T-16 is a feature packed radio with more options available in it than mine.
My tx can do everything I need and the touchscreen makes setups, model swapping and fast adjustments in settings super fast and easy and the graphical interface coupled with that touchscreen makes complicated configurations a straight forward process but I would snap up a T16 tomorrow if it also had a touchscreen but I use that feature every time I fly and won't buy a tx without it now I have been used to having it for two years.
My tx is pricey, It sells for between $143 and $180.
