BATTLEAXE
It could be a multitude of things, all are good places to look for any defects or discrepancies. I haven't built the Simple Cub myself yet so I can't make any opinions on the plane itself. But as a beginner in the flying the planes I build game I will tell you that I have crashed and trashed twice as many planes as I have flown successfully to date, actually there might even be a wider spread to that ratio. I have a dozen FT plans sitting on my bench that have been built at least once, 3 of them have been built twice. Planes i have on the shelf right now, Baby Blender, Spitfire, half a Simple Scout which took a good hit last night and tore the tail off, Mini Mustang, a Mini Speedster Biplane and a Shrubsmacker (Mini Storch). It has only been recently as in the past couple of weeks that i have actually been able to get a whole battery through any of them without significant damage. My first plane i built wasn't a DTFB design but a from scratch Dehavilland Beaver that I spent the better part of 2 months building with no idea on what i was doing. That was a disappointment in a half to say the least.I love ball parks.
I hate chain link fence, steel reinforced concrete, and metal bleachers.
All of which do weird things to radio and horrid things to motors, props, wings, cameras, and ESCs.
Outfield is a cool place to fly. Infield, not so much. At least not when you are learning, IMO.
Bummer about the foam, but how are the electronics?
Assuming the electronics are sound, YOU CAN FIX THIS. You built this. You can totally fix this.
When you do, before you maiden the plane, test the flight control directions and film that test so we can see both the control surfaces and the movement of the sticks. Then film the balance and show the CG with the lipo in place.
I'm bettin' you had a reversed rudder today or a tail heavy plane.
The one thing i did learn the hard way over time, plane after wrecked plane, I wasn't using enough throttle on take off or hand launch. I was apprehensive to damage the plane which on it's own is what damaged the plane. Not enough airspeed over the control surfaces and wing to create enough lift to get the aerodynamics to take effect and work the plane. in being to scared to crash that's exactly what I served myself, crash after crash. Now i like to start just over half throttle on a hand launch and give it more throttle upon it leaving my hand, even up to 3/4 just to get it to climb an not stall. plane seems to lose a lot of momentum and speed once it leaves the ground or your hand. not only does it have to pull itself forward but once it loses contact with the ground or your hand now it has a second job of creating lift to defy gravity, effectively working twice as hard. Now that I look at it like that I am so much more confident in my launches, and once it's in the air it is so much easier to correct anything else with trim.
That's my 2 cents worth as a beginner to a beginner. Maybe it helps, maybe it doesn't. Either way don't give up. Once it clicks the learning curve is so expediential that you will be surprised everytime you take flight. Thx for reading
