Hi!
This is my very first post on this forum (but I did post an article about scout xl travel kit)
This is to present my 9g operated, 3d printed retractable landing gear. It has been bench tested and can hold at least 5kg of force in all axis and each unit weight 50g at 100% infill, servo included. They are 50 mm wide and can fit in a power pod as main landing gear *see note one below*.
material required:
stl files, bbq skewer (3.5 to 3mm diameter), 3-4 9G servo, CA glue.
They are part of a 150% FT 22 im designing at the moment.
-The ''CF'' tag refer to the bracket being compatible with a 7mm CF (spar).
-The ''BBQ'' refer to skewers being used to transfer the load from the gear to the plane.
-The main struts use 2 bbq skewer as moving piece on the suspension
-The nose strut uses a single 6mm CF rod that can rotate on its axis and provide steering cabapility and suspension simultaneously.
-All of there shocks uses 3 inch rubber band and each unit is preloaded with about 400g force and provide 1200g of force when at full deflection (1 inch travel). Stiffness can be modified when using stronger or weaker rubber band and playing with preload.
note:
*note 1*: this kit can be mounted in line with the plane (nose gear in picture) or sideway (main gear in picture). For in line operations, I will soon post an additionnal axle file that allow for proper axle and wheel angle.
Im new to posting here and would like some tips to be able to post videos (retracts in action). For the time being, I'll post the video via the facebook page FT fans, under Maxime Valiquette.
Cheers
#1 edit 15 oct: added: axle mk3 V2, axle mk3 V2 offset and bbq strut C1
note: all the pieces are now available to build in line retract, in addition to having and offset connector for increased flexibility to fit models.
material required:
note:
Cheers
