I thought that this would be interesting to some readers given a few other comments about not liking the models where the wings are glued in position to the fuselage, so here's my modification to the Simple Scout, from the UK.
Having printed out the plans at 100% scale I also took a look at the main wing incidence versus tailplane incidence. From my measurements this looked to be about 0.5 degrees which is low compared with the more usual 3 degrees. So my modifications are;
1. Make the wing removable
2. Increase the wing incidence to about 3 degrees to reduce flying speed
The overall build is as per the Flite Test video but without cutting out the fuselage for the wing and a modification to the turtle deck structure.
Here's the fuselage built with then the revised cutout marked to accept a wing on top. Note the cutout shape has a step to reflect the underside of the wing.
Cutout made and wing placed in fuselage:
Here's the modified turtledeck formers being built:
Here's the turtledeck parts cut out ready for gluing:
Here's the completed turtledeck formers:
And the turtledeck glued in:
Here's the model with the paint job (natural canvas effect):
Finally, to follow the WW1 scout semi-scale theme, I went for a Royal Flying Corps canvas type colour and roundels. The roundels and other decals were just found on the internet and printed to paper then stuck with PVA glue with lacquer sprayed over the top.
You can see above that the wing is banded on with two barbeque skewers pushed through the fuselage. At some point I shall fit a pilot and a Lewis gun for good measure plus maybe some weathering.
Maiden flight was uneventful. I powered this with a 1400Kv motor with 8x4 prop and 3 cell 11.1v 1000mAh LiPo pack. Initially flew with rudder, elevator and motor but then quickly added ailerons/flaperons. Performance is ok. Weight came to about 20oz with battery pack.
Really pleased with this modification and being to separate the wing from the fuselage.
I'm still a novice pilot in that transition from rudder to aileron and chose the Scout as an interesting next step from a high wing trainer. Hope to post a flight video at some point....
Justin
Justin
