Hi Sponz, are you going to be adding the landing gear to the FT Legacy plans
That is the plan.
never mind ...will downsize the full size ...as they seem to be sponzified....any news on the mini guinea updated plans from sponz ???
Hi SPONZ, we who build owe you a huge debt of gratitude for the plans you do.I will be posting them shortly...
I am confused - went to your recent post here https://www.flitetest.com/articles/printing-flite-test-plans about printing plans, and was relieved to read your knowledge that many of us use A4 and not Ansi A letter size paper to print. When I went to the FT Legacy plan download page, my choices were these: View attachment 121991 and I cannot understand which file I need. (I want to print tiled A4) Can someone help me please?
This info is toward the top of the first post in this thread. Hope this clears things up.
All-In-One: Includes Full-Size, A-Size, and B-Size plans in one file
Full-Size: 34 x 22 non-tiled plans (fits ANSI D and ISO A1, requires a large format plotter)
A-Size: 7.5 x 10.5 tiled plans (fits US letter and ISO A4, standard size home printer)
B-Size: 10.5 x 15 tiled plans (fits US Ledger and ISO A3, requires a larger format printer)
*If you still do not know what size you should print, use A-Size.
AIO : All-In-One
FS : Full-Size
TA : Tiled A-Size
TB : Tiled B-Size
Sponz these are great and thank you for what you do. I’m vulturing for the new A10 plans. Do you have an ETA? Cant wait. Cheers!
@Obiewan thank you for the kind words.
Keep circling for a little longer. I'm just getting started on the plans. This is by far the largest and most challenging plan set that I have worked on for Flite Test. It's going to take some time to get them complete. I'm pretty sure that someone at Flite Test already stated that it will release the last week of January. That gives me about 2 weeks to get them done. It's going to be tight to have them ready when the build video drops. But, that is always the goal.
This is what an 11 sheet foam kit looks like. She's a beast!
I'm going to make a twin 50mm EDF if I get enough votes.So I guess that gives me the time I need to complete the 4x Bloody Wonder's I'm building for Air combat at the field, and the founders plane. Should be perfect timing
But Sponz - Any chance you can give us a hint as to what size the inner diameter of the engine nacelles for the A-10 are? Would rather do a twin 64mm or 70mm fan setup than props
That’s what I will try instead of EDF’sthank you sir. Ok little big for any of the EDF's that I have so maybe some 3x5x5's
