kilroy07
Uh huh...Bullets for the motor wiring arrived yesterday and annoyingly, I bought the wrong size. Got 3mm, needed 3.5mm.
Another order placed.
I can't finish the nose until I have these bullets...delays, delays!!!
I suspect you are just sandbagging until all of us get ours painted...
(That is one really sweet scoop I have to admit!)
Okay, since you and @mayan asked (his Maiden video is up BTW.) here we go;What powertrain (prop, motor, esc, bec, batt) were you using? If everything came in at a reasonable temp, I'd like to duplicate it.
Motor;
Sunnysky 2216-8 1250Kv
https://www.aliexpress.com/item/32456975952.html?spm=2114.13010708.0.0.3a994c4delFi5H
Foam filling optional.
Prop;
9x6 3-Blade
https://www.aliexpress.com/item/32810160030.html?spm=2114.13010708.0.0.3a994c4dM9bt2e
(I have "issues"... (brief pause) with 2 blade props on warbirds that "should" have 3 or 4 blade... )
Spinner;
https://www.aliexpress.com/item/32866135438.html?spm=2114.13010708.0.0.3a994c4dukdzsv
Another "must have"...
ESC;
One of my "upgraded" 30A $4 ESCs.
I basically take one of these;
https://www.aliexpress.com/item/32700887789.html?spm=2114.13010708.0.0.3a994c4d4jP6mf
(and I have noticed the quality of these "branded" ESCs are better than the no label brand.)
Remove the line from the BEC (which IMHO cause 99% of the heat issues with these ESCs) and replace it with one of these;
https://www.aliexpress.com/item/32646325986.html?spm=2114.13010708.0.0.3a994c4dWZPHWh
JUST be SURE to set the output voltage BEFORE you connect anything to it... (I lost a servo tester to this mistake...)
Although it would be a lot easier to just use one of these (but I'm working on the cheap here.)
https://www.aliexpress.com/item/32920672534.html?spm=2114.13010708.0.0.3a994c4dsorYXw
Battery;
Kylin 2200mAh 3 cell 25C
It's one of the first battery packs I bought (I have 2). Before I knew NOT to store Lipos at full charge... so they sometimes have a bit of sag to them.
But I use them for Maidens... in case (you know...) something goes horribly wrong. Like my recent wing "adventure..."
