jayz 84
Ive heard that about balancing before, but not put so eloquently We had thunderstorms roll through last night so no flying, but I cut my servo leads tighter, i probably had 7 or 8 inches of excess so i clipped them all to the correct length and soldered them to shorter leads into the rx. I also moved all the electronics as far forward as possible. My CG is about a half inch to an inch behind the spar now with the battery as far forward as possible, which is miles better than before. I have a couple fishing sinkers lying around so i was thinking i would try to even the balance out by loading them into the front of the power pod.
wow man after all of the your cg is still far out. so ya the only thing you have left to do is dead weight. in the future with that heavy foam board I would go with a bigger battery instead of dead weight atleast you get use outta it. and I would go with a push wire set up for your rudder and elevator and place your servos under the canopy getting the weight off the tail
