BATTLEAXE
It's the size of the can in mm'sRimFire .15 35-36-1200
What does the 35-36 designate?
Aaahhh, i see you are coming around to the darkside! Thats awesome you are getting more confidence in the Sportster. I knew it would be a few flights before you would lose grip on the Scout. It is nice when you go from a trainer plane to something that has some accuracy and predictabilty. Now you are gonna start seeing a bunch of planes you want to try and you will be a building fool, I look forward to your upcoming projects, oh and your P-40 maiden!I flew the Sportster again today, ran 5 more batteries. I'm much more comfortable with it now. It flies more "scale" than the Scout, it doesn't slip as much, carving nicer turns. I've now done all the maneuvers that I know with the Sportster. It rolls cleaner for me than the Scout. Played around with the rates and trim some, tweaking things in. The best landing I have had yet, is the maiden landing. I've bonked it a few times. I flew the Scout some too today, orientation confusion with the Scout is a real issue (even close). Going forward, I'll make sure the bottom of the wings will look different than the tops.
The Sportster is more stable and predictable than the Scout, but it definitely needs more power. No issues with the lower wing.
I'm going to try to get another session in tomorrow morning before an appointment. The weather turns bad Friday through the weekend, so flying isn't likely. Rain and lots of wind in the forecast. So I'll fit it in tomorrow.
You said you dinged her up a bit, any damage?
Yea there are a few more to come lolA bad maidens just make the good maidens so much sweeter.
Sportster really knows how to take hits don't itA little issue with the power pod to fuse. Not visible. I broke 2 props today, one on the Scout and one on the Sportster. Not sure where my landing skills went today, they seemed to be taking the day off.
@Marty72 my favorite prop for the c pack (I still use the old emax one) is the APC 10x5. It’s super durable and as you said, more speed with no losses of thrust. It’s my go to prop at the moment. I also think it’s alright with 4s. I haven’t done much with it in 4s yet, but with a 9x6 and a lot of full throttle, the motor wasn’t too hot to touch, so with a 10x5 on the throttle level I usually fly, I think it will be ok. Of course yours is the radial which is better than mine so you can even push yours farther. Have you tried the 10x4.7 flow fly props? I find they produce the most thrust out of the props I’ve tested, although I haven’t compared them side by side to the 10x5 yet.
Yeah, even the APC slow flys break easily. I was having a blast doing full speed low passes and low inverted passes on 4s for the first time.Are you talking about the HQ SLOW fly props 10x4.7? If so, I order some, they will be here today. I like the HQ 10x4.5 but they sure do break easy. I have a 10x4.7 APC on the Scout, may try a 9x6 for giggles.
I don't run wide open much, seems like I always find the knee in the curve for throttle/speed and hang out there. Wide open is for emergencies and vert climbing (for me).
Yeah you are hitting the tendencies of a low wing compared to a high wing. With a high wing (or in the case of the Scout, higher wing) it will have a pendulum effect where the majority of the plane hangs on the wing, being a little more stable. A low wing you have more pitch sensitivity because the weight and drag are above the lifting surface. Which is what I am sure you have figured out already. Plus the Sportster is a heavier plane then the Scout so the power out of an attempted landing is kind of lacking with the C pack. Have you tried a 10x45 stock FT prop on the Sportster yet? Or is that what you started with?I got more flying in this morning, sunrise. The wind was down and I had a little time, so I went. Today, like yesterday was a bit cool for Fl (in the 40s) but very little wind. I learned many years ago living here, that if you want glassy water (calm winds) for slalom skiing, go at sunrise. It's true for flying as well. Anyway, I ran 4 batteries in the Sportster and 2 in the Scout. The Scout is dialed in right now with a 9x6 prop and the C pack. It's pretty fast (at least to me). I'm still trying to get more comfortable with the Sportster. I now see the major difference the low wing design, landing the plane. If I come in for a landing with the Sportster and do everything right, no difference really but if I come in, and it looks like I'm landing short, it's very difficult to add throttle and set up for another landing. The best option is to abort, gas it and come back around. The Sportster will tip back and forth and is more difficult to control near stall speed, close to the ground. The Scout much more controllable and you can make all the corrections necessary for landing, no problem.
The area that I'm struggling with the most with the Sportster is hand launch, I am not getting good launches consistently. Some are very wild, pulse raising events. I think this is also the low wing design. I've got the Scout perfected, it's a nice clean steady climb out without drama. I'm working on the Sportster launch and think I've figured it out but need a few more launches to know for sure. I think the answer is a steeper angle toss with a lot more throttle (from my hand). A throttle level greater than 3/4. Adding more throttle after the hand launch results in a rather sharp torque roll (plus the plane is dropping before I can get my hand to the controls). I think Battleaxe is right about this plane needing a more powerful motor than the C pack. I feel it's barely enough at times.
Put lights on you planes to fly at nightOh yeah, I've already got 27 flights on the Sportster, solid plane and looks good. Here's the wind forecast, I got to fly at the lows this morning and then it let loose. The light orange vertical lines are sunrise and sunset. The blue bands are night.
That is a sharp looking plane man, Still looks like you haven't even flown it yet. Is that still the 9x6 prop you have on there, electric only?The Sportster got a little cosmetic love today. Added a spinner, hood extension and will add a black APC 10x5 prop when I get it (it was suppose to be here today). The nose looked really incomplete to me after adding the spinner. BTW, if you order directly from APC, you can get the exact props, same prices as the gray APC props from flitetest. I don't understand why they make gray props.
