jpot1
I was looking for a new project to continue my 3D printed / DTFB hybrid designs and stumbled across @SP0NZ 's intruder thread. Reached out and got the ok to leverage the work of SP0NZ and started the design.
Took the top/side layouts and some images graciously shared and drafted a quick outline in Fusion 360 which I converted to SVG to do a quick chuck glider to figure out CG. Chuck glider is actually full size what I expect the final model to be at 34" wingspan. A couple of glide tests and CG is right at rear of the KFM step in the chuck glider - I completely lucked out on that one.
Multiple stumbles in Fusion360 but made enough progress on this one to start to share some pictures. The plan is to print this in vase mode using LW-PLA with two F pack motors up front. I'm hopeful a 1300 3s in the nose is enough to balance and version 1 will have DTFB Hstab and fin.
F360 so far is below. Wing have no spars yet nor have I figured out the nacelle but making progress.
When I'm ready, I'd like to ask 2-3 volunteers on this forum to test print and give me feedback. I'll be printing at the same time so warning as there may be some re-do's. Ultimately I'd like to offer the STL's discounted to the FT community as a small thank you for all the benefits I've received over the years using this forum. I certainly would not mind if anyone wishes to make a small donation as there is quite a bit of time invested, and a lot of LW-PLA samples
I'll keep posting as progress is made but I'm a few weeks away from the first STLs being ready.
Also check out my prior DTFB designs through the link in my signature. Thx!
