STOL Cargo Plane
loco3341
I need help designing/building a Cargo plane, That's also capable of STOL (short take off and landing).
for the stol problem i was working on the Coandă effect like the AN-72 or Boeing YC-14.
I was wondering if foam and tapes twins plane would be a good test bed.
can I use edf on the twins?
pgerts
Old age member
I assume that you are thinking of the Cargo-Twin.
It is a really great STOL Cargo plane if you are not afraid of the size.
I am using the old TGY 25 gram 1700 KV "blue wonder" but for "EDF" i shold use the 3000 KV version with twice-plus power to the 1700 KV version.
earthsciteach
You are FAR better off using props for STOL than EDFs. EDFs do not accelerate as well as prop planes.
Most important question - what size and weight of payload are you carrying?
loco3341
Sorry I wasn't a little bit clearer.
I was hoping to use i as a "tow" plane, bomber and to experiment with parasite fighters's.
and if possible keep the maneuverability seen in the cargo twin
THANKS for all the help:)
