Suggestions needed for affordable fixed wing kit style setup
landedit
Hello all, I'm looking for recommendations on a complete setup for a fixed wing aircraft. I have the FatShark goggles already but I get overwhelmed by all the camera and antenna options. I'm looking for something in the maybe $25~60ish range? It doesn't need to be super HD quality or anything. Just something that I can pin to the tail of a fixed wing airplane and go fly. I think at this point I'll need a camera, attenna and battery? Anything I'm missing? Also any advice or guidance on FPV would be helpful. I'm pretty new to it as I'm sure you can tell :)
Thanks!
Aireal Anarchist
many will suggest the $25 AIO camera and TX combos most are only 25mw some are more powerful, they work well and are $25ish, but since you dropped the cash for Fatsharks I personally would look at more serious fpv gear , the AIO 25mw are only good for approx 1500 ft
this cam combo would be my suggestion 600mwTX will get serious distance, I have & use a couple of these cheap rigs and very clean image
https://www.banggood.com/EWRF-TS582...mera-For-RC-Drone-p-1388365.html?rmmds=search
add a cheapo $9 OSD and you will have remaining battery voltage (like a gas gauge) and it also gives you current flight time and your still within budget
https://hobbyking.com/en_us/super-simple-mini-osd-system-for-fpv.html
upgrade the dipole antenna to a cheap but very good AOMWAY cloverleaf polarized antenna
https://www.ebay.com/itm/Aomway-5-8...510950?hash=item4af507d466:g:mYkAAOSwnH1WYJpW
this doesn exceed your budget very much and would be my budget
opinion cause I use them and I do have the AIO cams and expensive caddix Tarsier with a 1 watt TBS transmitter so I have compared my fpv dollars and I beleve this will suit your existing FPV gear well and still be on a bugdget
I have gone 2 miles on a 200mW vTx & clover leaf antennas.
In my part of the world, an OSD with GPS is mandatory. Its so easy to get lost in an ocean of corn. I need an arrow to point the way home. Here is the first in a series with an economical solution.
