varg
Build cheap, crash cheap
I've been using the irangex IRX4+ for a little over a year with my X7 to use spektrum gear and I figured I'd share what I've learned in that year. I'm no programmer, I try to avoid that stuff, so I can't get into the firmware. The most important thing to do when using this module is to change the channel order when you set your model up in openTX. As an frsky only guy up until I got this module, channel order was pretty much irrelevant to me, but the module expects AETR and switches things internally to the protocol's expected order. In a nano CPS, travel had to be limited to 80% on the output tab for the flight controller, in typical spektrum receivers such as the AR6100e and AR636 I have used this has not been necessary, the travels and mixes were set up as you would with frsky receivers. As for range, I have yet to find its limits. Definitely adequate for flying within visual range on mini receivers. As I do not fly anything FPV on anything but frsky receivers, I can't tell you how it is to fly through trees or behind structures or terrain, but the range is adequate for flying conventionally. There is a caveat with RSSI on spektrum receivers though, in short; it's useless. With the AR636 AS3X receiver I got signal strength low alerts at ridiculously short ranges during my range check. Through some searches, I saw that others said that the telemetry output of the Spektrum receivers is shorter range than frsky output. A conventional range check, walking away while watching control surfaces move, confirmed this; even quite a distance past the announcement of "telemetry lost" the plane was still responsive. The module is best used in serial mode, with the protocol selection within the model setup menu. There are too many protocol options for one person to ever use them all imo, but they're much easier to clearly select in serial mode, with options like DSM2/DSMX 11/22ms being easily selectable. With my sample size of one, I can recommend this module. It's an easy and cheap solution to using DSMX, among other things, with your Taranis. If you're flying expensive planes with spektrum receivers, I'd just pick up a used spektrum radio. What's a couple hundred bucks when the model is a few thousand?
Anyone else using one of these modules? Post your experiences in this thread. It's good to have these repositories of information available for search results when someone has questions.
