wrongflyer
wrongflyer
Hi, it seems the airflow over the elevons is working great for elevation but seems to do nothing on the roll, this may be because the volume of air flow over both control surfaces in elevator mode are in affect thrust vectoring in one direction which is giving you positive directional control, thumbs up! however it would seem that the two control surfaces in the roll dont have enought surface area to give positive control, all the weight down low may also be a contributing factor as it is probably acting as apendulum.
I would use the rear outside 1/4 of both sides of the box as a twin rudder, being on the outside and the thrust should give you more of a turning affect kicking the rear end out if you like.
Just my thoughts hope they are of some use.
Wrongflyer. ;-)
Wrongflyer. ;-)
