Wildthing
What ya printing now? Another plane?
A tray for my Jumper T16, similar to what I have fro my FlySky TX.
https://forum.flitetest.com/index.php?threads/fs-i6s-and-jumper-t16.57825/post-535180
What's next a wheel chair, that would be easy to mount a tray to. You could be the Stephen Hawking of RC. You could be as famous as him!A tray for my Jumper T16, similar to what I have fro my FlySky TX.
Heck of an idea, thrust vectoring for steeringWhat's next a wheel chair, that would be easy to mount a tray to. You could be the Stephen Hawking of RC. You could be as famous as him!
You could 3D print the whole chair, but differential thrust might be more effectiveHeck of an idea, thrust vectoring for steering
Well, that took an unexpected turn...You could 3D print the whole chair, but differential thrust might be more effective
It's old hat for a couple of old Canucks like us. This is light weight, you should see the rat pack threadWell, that took an unexpected turn...
Looks good, the integrated control horn Take some guess work out of it. As far as the registers go the suggested areas on the land will be subjective depending on whether someone has a 3D printer or not. I don't have one so the cardstock hinges work great, move freely and haven't loosened up from wear at all. The 2mm overlap leaves room to iron all the edges for strength and a smooth look. Great job thanks @Wildthing
I can't seem to open it, does it need a special app to work?How much overlap from wing to aileron do you have. With me offsetting the registers in 3mm from the edge I have about 7 or 8mm overlap on the test piece.
Here is a print ready G-code with all the control horns including the mirrored CH1 plus one for the elevator and rudder. Your bed has to be minimum 200mm x 200mm , mine is 220mm x 220mm .
The overlap will be subjective as well, just like the amount of throw you will get given the length of servo arm you use. As I can tell from the full scale being it uses flaperon's, when deployed in full down position the air flow between the bottom of the wing and the LE on the aileron is almost cut right off. I don't think this needs to be the case here so the overlap does not need to be drastic, causing pitch instability. If in full down position you still have a 1/2 - 5/8" gap that should be fine. Mine has about a 5-6mm overlap when the ailerons are parallel to the bottom of the wing
I think if there was a complete cut off in the down position there would be no bleed off and make a flaperon to effective causing pitch and control problems when trying to land. Reducing the amount of throw with the flaperon will help with this too.It should be very close to what you have then, I think the space between the aileron and wing is about 20mm which is what yours should be about.
I think if a person wanted to close off flow when fully down you just make the ailerons a little wider in depth and offset the aileron hinges farther in. Or even in your case you could just glue a strip of foam to the leading edge of the aileron.
By the way I braved the cold and took the plans down to Staples to print . Now I will have to brave the cold again to go get them .I think if there was a complete cut off in the down position there would be no bleed off and make a flaperon to effective causing pitch and control problems when trying to land. Reducing the amount of throw with the flaperon will help with this too.
You gotta educate this poor snowless guy here! 😆Is that like a snow tumbleweed or something? Or bad snow traffic?it sure does bring out the snow snakes, they are just cruising down the streets right now.
Pretty sure it's actually a snake...You gotta educate this poor snowless guy here! 😆Is that like a snow tumbleweed or something? Or bad snow traffic?
I should almost let @BATTLEAXE comment firstYou gotta educate this poor snowless guy here! 😆Is that like a snow tumbleweed or something? Or bad snow traffic?
