Okay here is my progress so far
I also realized that I need to add the power pod to the plans so I will try and do this later tonight. Plus I might do a quick edit of v1 flying.
Here is a test fit of where the motor placement will be
I also learned that you can use hot glue and paper if you don’t have any tape handy (I’m not building at home right now)
I am also just using 5g servos and a regular reviver so no special receivers or servos are needed.
I will hopefully finish the build tonight when I get home, and do you guys want me to edit the flight video or work on designing my next plane? (I’ll give you a hint, it’s either going to be a micro FT flyer/nutball or a micro motor glider)
