The TriKUZI effect V1 - My tricopter design
Jnr Kuzi
"Note: this design has been done on paper, i am yet to make proper plans"
_____________________________________________
So,I've been interested in multirotors for about 8months now, but the cost of building one is not friendly.lol so i spend most of time designing & drawing frame types & this one is my favourite so far.
I would like for you guys to build your own with my plans (which i will start working on tomorrow (02-09-2014) ) because I cant afford to build one but i'd really like to see my idea fly "literally"
I introduce to you the TriKUZI effect V1
Chasis/body : https://m.ak.fbcdn.net/sphotos-b.ak...884_743281705719063_7557250449597302990_o.jpg
angle view : https://scontent-a.xx.fbcdn.net/hph...151_743281709052396_6367116247267274081_o.jpg
Pros : I like the detail factor because it will be able to hold & protect all electronics while it still keeps a Neat Clean build.
Cons : i think, who ever builds it will need a powerful system because i suspect it will be a heavy one.. Which is bad for low budget rc Guys.
Specs :
Body - 20cm Long, 16cm wide
Booms - 15mm x 12mm x 250mm
Materials i recommend :
wood, wood, wood, unless you have access to a laser/cnc cutter that will give you the Ability to make a snap & glue model.
I hope you like it guys,Please give me feedback.
If you are on facebook, Please support by liking my page : www.facebook.com/marzzambia
Balu
Admin
You could try and shape the "roof" using some kind of plastic. which would make it a lot lighter. For the body and arms wood is a great material.
Jnr Kuzi
#3
hey balu, i was considering plastic too but then i thought a really slim wood like 2mm ply wood or balsa wood would give me a better design for the sides & then a plastic cannopy infront for the Fpv system.
Would that work?
Balu
Admin
Sure. Balsa should be light enough. Heck, you could even just use some paper / carton or similar since the "hood" is not a structural part.
