Lancenlink
Any ideas on this concept?
So you know how jets usually have the engine in the back and some canards in the front, well what if you replaced the canards with the engines (I swear I'm not drunk!). Essentially the concept was for a twin edf aircraft to have its motors rotate on an axis for improved STOL and aerobatic characteristics. I thought about thrust vectoring, but that was too complicated to work. It hit me that you could replace the canards with rotating engines to act as a pitch axis and still use elavons for regular flight. This is going to be a high wing so the faster air can go under the wing and blow over it. I created a digital sketch from my notebooks.
due to the engines being in the front, I'm guessing my battery will have to be in the rear to balance out the cg. Thank you in advance.
