mayan
I was telling @buzzbomb earlier in a post that I already built my third HB A/F Easy Edge, but before we can talk about that we have to talk about the second one I built.
The second one had BBQ skewers in the fuselage to try to re-enforce it, one over the wing the other under the wing. It helped with the fuselage not breaking but added a whole lot of weight making the A Pack setup not work well, but it still worked well with the F Pack on 5g servos. I don't recommend putting two BBQ skewers because they added a whole lot of weight, one would be enough. Also if you are putting a BBQ skewer in the fuselage don't glue it with Super77 it wont stick well. You'll have to add a whole lot of pressure and hold it there for a very long while before it dries up, and even then it might spring up. Like in the first one I sat up until 3 am to finish building it and totalled it in the morning the next day but how I totalled it is the question.
Watch the video bellow to find out. Will you find you!?
So now that we talked a bit about the second Easy Edge that I have built we can talk about the third one that I built, but I will leave that for a separate post.
