Ok I thought I was almost ready to maiden and then some gremlins came in and f@#*ed things around. I was doing a little vertical thrust test and then went to try the control surfaces, all was good until I tried the ailerons and all went bizerk, everything going nuts . Looked at the rx and light is flashing widley, not touching anything in a few seconds everything calmed down light went solid and surfaces centered . Tried rudder and elevator a bunch of times and nothing, just barely move the ailerons and all goes nuts again. Then for what ever reason lets do a thrust test again and within 5 seconds the motor slowed down to 25% , now what the heck? Put the battery back on the charger and it still had 12 volts so what gives. Tried programming the ailerons to channel 6 just to see if any different and that's a big nope, same nutso crap went on. So now I tried a different rx, same crap again along with the motor slowing down within a couple seconds and test the voltage and it is good. So concentrating on that I plug the voltage tester into the balance plug and then fired up the motor, cell 3 dropped to 4 volts almost instantly , shut the motor off and within 3 seconds it is back up to the same voltage as the other guys so a bad battery . Had that happen before where a cell would drop off instantly and then within a few seconds it would show good. So one issue solved, thought maybe the Y connector was causing issues so pull all the wiring apart and start testing individual servos. Found that one or two separate and even a tiny bit of a third one you were almost ok and was harder to make it act up but 2 servos on one circuit drawing fuel juice set it off instantly. NEW esc time, the bec can barely run 2 servos on separate channels and the rx at the same time.
Now my glitch is all my servos laying around are 40A and up and I am down to one 1300 3S battery . Just really ticked off right now.
