RipSmith
I have been reviewing Joshua Orchards build on the Top Flite Corsair. I have also been speaking with him directly regarding portions of my build. I am about 1/2 way through building my TF Corsair and have done some scale things on my build similar to Joshua build. I am current working through some initial wing building problems, such as to much filler, incorrect wing tip angles, etc. I have done the sheeting on my overall wing at least twice. I am finishing up the repairs and move forward at the same time with the fuselage. I have added a lot of LED lighting to my Corsair. I have the dorsal (Red color), and tail (White) anti collision lights, I have the single landing light (White), the red/green navigation lights, the IFF (Amber, Green, Red) and formation (Blue) lights. I have dual aileron and flap servos, and E-Flite electric retracts(main gear), with functioning gear door, and a tail wheel retract from the Flightline 1600MM Corsair. I do not have folding wings........ they are still a possibility. I am adding the oil coolers that Joshua used and the sliding canopy. I will have a pilot in mine, there for I am not animating the cockpit. I will be researching what it would take to get the pilot to reach up and act like his is pushing the canopy open since the Corsair didn't have an automated canopy. I repeat researching this item !
I plan on fiber glassing the wing, using 3/4 OZ cloth and the Minwax Polycrylic, with a sanding sealer under the cloth. I have a DLE20-RA that I am using for power with a 3 bladed prop. I started this project in October of 2018. I will be building my own cockpit interior as the Top Flite one is no longer available, and a custom cockpit, while beautiful, is way out of my price range. The pictures that are with this portion are early in the project so they might be difficult to follow. I will add a second set that is more current things that I am working on.
The servo shown here is what I put in the wing for the aileron servos. Plenty of torque for the job. I am going to try and make the control rod come out in the middle of the TE.
