Tricopter Trouble
mtjahnke
Brunet_Island
I had a working Tricopter - David's RCExplorer v.3 using Cleanflight Naze 1.12.0. I've been in school and have not had time to work on it until l recently. When I connected it to Cleanflight, it forced me to upgrade to 2.0.2. Now I can't get the front two motors to spin. I can connect them directly to the receiver and they work, so it is not a wiring problem as far as I can tell.
It recognizes all the inputs from my transmitter in the correct direction. On the motors tab in Cleanflight, here is what is happening:
Master control
Motors 1-3 on the screen go from 1000 to 2000 when I raise and lower the master control. What happens on the tricopter is the rear motor (motor 1 in the schematic on the screen) goes from zero to full throttle and it tilts from far left to far right (far right at full throttle, far left at zero throttle).
Motor 1 control
Controls servo only when I raise and lower it
Motor 2 control
Controls nothing
Motor 3 control
Controls speed of the rear motor (motor 1)
I tried going to RCExplorer and downloading David's .dex file and flashed my Naze 32 rev 6 with that. . . Same issue.
I'm using a CPPM connection from an OrangeRx receiver if that makes a difference.
Does anyone have any suggestions? I'm stumped.
PsyBorg
Wake up! Time to fly!
Did the default channel mapping change between the versions? Like from AETR to TAER maybe?
mtjahnke
Brunet_Island
The channel mapping is correct. Pitch, yaw, roll, throttle, and 3 Aux channels all look correct on the receiver tab.
cranialrectosis
I had to go to Betaflight when this happened to me. I ended up going to Triflight in Betaflight to fix it all but the copter flies GREAT today! :)
mtjahnke
Brunet_Island
Working now. Thanks for the response
I got it working tonight. I reverted to Cleanflight 1.1.0 with 1.12.0 NAZE32 hex file. I was able to use my old settings and it works fine.
