Hi guys! This thread is just meant for my own records and to provide information for anyone who wants it, I hope you enjoy it and if you have any questions or advice, please let me know.
I chose the Tricopter V3 because it seemed to cover all the bases, fast and fluid flight, good aerial photography platform, relatively cheap and has good support.
So anyway, Ive just moved to Canada from New Zealand, so I had to leave all my RC stuff at home, so I had to buy everything again, Tx, soldering iron etc. So heres the list.
- Taranis plus
- X8R receiver
- FrSky smart port voltage telemetry sensor
- FrSky 150mm receiver antenna
- Tricopter V3 frame and spares
- All recommended parts for 900kv 4s set up from RCexplorer
- KK2 mini
- Kydex thermo plastic for snow shoes.
- Pink insulation foam
- Ebay USBasp programmer
So the basic build was as David does it in his videos. So heres some photos.
I wanted to make this as snow proof as possible, being its going to land in snow lots.
So I added heat shrink to all the ESC's and then hot glued the openings. To make them pretty much water proof.
I also didn't like the short RX antenna's, so I bought the 15cm versions too. They were easy to attach, just split the receiver casing open and unclip and re-clip the new ones on. Then I added some hot glue just for piece of mind.
As the normal landing feet aren't going to do anything in the snow I wanted to make some replacements, I don't have a 3d printer or anything so I decided to improvise. I knew of a product called Kydex so I ordered some. Its a thermo-plastic, yo put it in the oven for 3 minutes at 400F then take it out, mould it quickly and let it cool. Super easy to work with, usually used for making gun holsters. I made a mould and made some legs, they turned out awesome and super strong with just enough bounce. I drilled for 3 zip ties because for the maiden I had 2 on the stock legs and they snapped way too easily.
I flashed the KK-mini with stevies latest and set all the PID's to what David said, took it out for its maiden and it went perfect. My flying is questionable, but I don't have a heap of experience.
Ill post a photo of it completed soon. But here is some flying pics.
I made an edit yesterday of my 3rd time out. Went awesome, can't wait to get some FPV gear on it and do some faster distance flying.
https://www.youtube.com/watch?v=1KaCxEuSi6w
- Taranis plus
- X8R receiver
- KK2 mini
