It never occurred to me to not use a heli model, I was surprised to hear most people used plane mode. I think it's probably me being mainly a heli pilot and being comfortable with that Tx mode, whereas some of the heli features could be intimidating to a plane guy.
I've tried that too, but the same thing happen...that's why I'm a bit worried. Just before, I calibrated the throttle range, and from this point everything went wrong.
I've had the BMS-385DMAX Digital Servo on order for weeks now with HK. Getting ready to cancel the entire order long with it. Does anyone know a great alternative to this?
I don't like that servo - mine stripped in a crash. I now use a standard size servo, it's bigger and a bit heavier but it hasn't broken after quite a few crashes. You won't be able to mount it the same way though.
thats true .
at firs i used a 2.5kgcm servo then a 2.2kgcm serco . both broke quickly . i checked on rcexplore and david uses a 4.2kgcm so i then bought that one coz it was the cheapest digital mg with high torque
thats true .
When my BMS servo broke I took it apart - and one of the gears was nylon and had stripped. I hated that, as $20 is a lot for me. The servo I'm using now isn't even MG or digital.
all metal gear servos have one nylon gear in them . the high end ones are replaceable . this saves the electronics if the servo is stalled and it allows that gear to strip . i used hxt900 gears in my small 9g size metal gear servos wen they stripped
Is it normal that I always need to trim (a lot) my tricopter on my transmitter because my yaw makes it drift to one side and my yaw gyro is set at 75% ?
You can also use sub trims to try level it out aswell as if you have a kk2.0 you can trim it in there by adjusting the servo offset but i dont recommend that
