irekkin
I guess I should give alittle info on my tri-copter then explain my issue. this is basically a David W. design, ht 750 motors, kk2 board with the latest stieves (sp?) firmware, afro 20 amp esc's, taranis plus tx and frsky rx. I can't tell you my p and I settings right off the top of my head but they are fairly conservative the problem i'm having is with the throttle. I can not hit that sweet spot where it will hover in one spot for any length of time. actually on the taranis it feels like the sweet spot is between " clicks " on the throttle stick, if that makes sense. would this be something in the hardware/ gimbal or is it something I need to adjust in the programing. if I could eliminate the constant up and down I don't think the rest would be hard to dial in. tia.
