Foxbodyford
Just finished my FT Bloody Wonder build and flew it this weekend. Had my throws a bit too large at first and wasn't so smooth to fly but that was an easy adjustment. The problems that I have are first when flying quickly the tail wobbles side to side. Not a big issue most of the time but it does throw the plane off some.
The real issue is I'm running a Red Brick 50A ESC, D2826-6 2200KV motor on a 3S 1000mah battery. When I run a larger than 6" prop the motor stops at anything above half throttle. One a 6" prop it shuts off at full throttle, and with a 5" prop it flew 2/3rds of a full pack thru before stalling. If I throttle down for a second or two i can throttle back up. I tried running 2 3S 1000 batteries in parallel and was able to run the 6" prop until nearly drained.
Even with these issues I've enjoyed flying the plane.
